UpyopyoSky Posted December 30, 2022 Share Posted December 30, 2022 Hi, I am studying how to make OnCreated.py by exporting codes with asCode. So far, I understood a procedure: 1 Create a new folder and create some parameters inside of the folder in edit parameter interface on a node. 2 Use findFolder() to take a new folder tab, and write out a python code with as Code. 3 Create actual a xxx_OnCreated.py that either imports or copy&paste the #2 written code. Questions are : 1 Can we export multi folder tabs at once as one master code? 2 Can we export expressions existing in a default parameter AND new folder tabs together, instead of separately? (I know I can manually add this code into OnCreated.py later.. ) I think a problem is that, if we export all folders and parameters including default param&folders, onCreated.py will get error due to the default one including. That makes this procedures difficult. # export new folder and its parameters. Let's say exportTab.py node = hou.node("/out/geometry1") ptg = node.parmTemplateGroup() folder = ptg.findFolder("NewFolder1") with open('f:/exportTab.py','w') as f: f.write( folder.asCode(function_name='createTab') ) ## Questions are ## I want to export NewFolder1 and NewFolder2 and NewFolder3 together and do f.write ## I want to export an expression together, for instance, "/obj/geo1/out_render" in Geometry1 > SOP Path param here, and do f.write. ## I could manually paste later like a node.parm('soppath').set('/obj/geo1/out_render') but ideally export together here.. #Then Let's say this is , Geoemetry_OnCreated.py, and try to attach the exported folder tab and parameters import exportTab node = kwargs['node'] ptg = node.parmTemplateGroup() defaultFolder = hou.FolderParmTemplate('default', 'Default', parm_templates=ptg.entriesWithoutFolders()) for p in ptg.entriesWithoutFolders(): ptg.remove(p) ptg.append(defaultFolder) ht = exportTab.createTab() ptg.append(ht) node.setParmTemplateGroup(ptg) Maybe my explanation is confusing, but I hope the code and screenshot help to show what I try to do. In other words, in conclusion, with the screenshot, how to export multi tabs¶m (#1) and expression(#2:sorry it's empty,,) ? Thanks! Quote Link to comment Share on other sites More sharing options...
