Arthur Spooner Posted January 17, 2023 Share Posted January 17, 2023 (edited) I would like to know, I watched one of the vellum master classes. And I remember whereas he re-did the mesh so that the topology was even, as in no tight edge loops as seen here. What I want to do is get vellum to soften these creases, they are too hard. I want some artist control over their softness so that the creases basically are not has hard is the only solution that which one of the master classes has done ? Edited January 17, 2023 by Arthur Spooner Quote Link to comment Share on other sites More sharing options...
maiden666 Posted January 17, 2023 Share Posted January 17, 2023 maybe decrease Rest_Angle_Scale down to zero 1 Quote Link to comment Share on other sites More sharing options...
Arthur Spooner Posted January 17, 2023 Author Share Posted January 17, 2023 5 hours ago, maiden666 said: maybe decrease Rest_Angle_Scale down to zero Thanks this helped, although; I probably will have to use the method in the masterclass as well because the scale collapses the edges as seen in the screen shot with the close edge loops too much that or use an attribute to control it. Quote Link to comment Share on other sites More sharing options...
