Seamlessly stitch two HeightFields
  • Neikke changed the title to Seamlessly stitch two HeightFields
Hi Natiq,
maybe there is a node for this, but you could overlap both height fields and sample them into a new one:
float band = chf('band');
float h_0 = volumesample(1, 'height', v@P);
float h_1 = volumesample(2, 'height', v@P);
float mask = smooth(-band, band, v@P.x);
f@height = lerp(h_0, h_1, mask);
hf_blend.hipFetching info...
  On 3/3/2023 at 1:56 PM, konstantin magnus said:
Hi Natiq,
Expand
Hey thanks a lot Konstantin! But will this method work if I need to stitch 6 height maps in this way? I marked areas that need to have perfectly matching relief accordigly:
Do you have an idea how to approach this?
Copy the height fields to the points of an octahedron to shape a cube, apply noise there and assign them to a cross.
cube.png.5b1aa18e42eebf7f76681bbe3b13621b.png cross.png.21e25fbb65042045b26fe7373ad7cf0b.png
Alternatively try sampling the world position noise from a cube mesh right away:
int index[] = array(0,2,1,3,5,4);
vector bb = relbbox(0, v@P);
vector uvw = set(bb.x, bb.z, 0.0);
vector pos = primuv(1, 'P', index[i@primnum], uvw);
float height = noise(pos * 50.0) * 200.0;
f@density = height;
heightfield_cube.hipncFetching info...
You could us the heightfield layer node to blend them together, overlap them a bit and then just paint a mask to control where the blend happens.
However, you might be better off just making one big terrain and then making a cross shape extrude it up and use a hf cutout by object.  If that works (I havent tried it) you would no longer have seams on any of the inner edges.
For the outter edges maybe this is easier to solve as a texturing problem?
Write out the Heightfield to disk and then in PS or in COPs, basically clone stamp the edges to get rid of any seams.  Then bring the new seamless texture back in through a heightfield file node.
  • 3 weeks later...
Expand
Thanks that totally makes sense. I'm not too familiar with COPs but it's definitely possible in PS or in Substance Designer. Thanks a lot for your help!
