Randomize name attribute
Dag
I need to randomize name attribute and have a dict of names wich I have to randomize with.
Dict is as rob, car, ed.
The way I wanted to do it is like this but it does not work
if(name == "name", switch(int(rand($PT)*3), 0, "rob", 1, "car", 2, "ed"), "don")
How can I get a result I want?
Thanks!
D.
Edited by Dag
You want to start with an array of names
string names[] = {"rob", "car", "ed"};
Then, you want a random number, which goes from zero to the amount of items in the array
float random_value = rand(@ptnum) * len(names);
You need an integer, so you can floor() the result
int random_id = floor(random_value);
This could be combined with the previous line, like so
int random_id = floor(rand(@ptnum) * len(names));
Then, you can fetch the corresponding index from your names array
string picked_name = names[random_id];
In the end, this is the result
string names[] = {"rob", "car", "ed"}; // Array of names
int random_id = floor(rand(@ptnum) * len(names)); // Random ID, from zero to the amount of items in the array
string picked_name = names[random_id]; // The name corresponding to the random ID
