Vex Moutian Option Of Height With Weighting Like Ramp
i animate a nurbs with vexMoutain.
and vex moutain scaleing as ramp...
start point is zero and end point is one..
but vex moutain heigt option don`t $PT, $ID etc..
only enable variable are $FF, $T..
Yes, VEX SOPs only evaluate the parameters once per cook, not once per point like the point SOP an others. However, you can override any parameter in a VEX SOP (or shader for that matter) by setting an attribute whose name, size, and type matches the parameter. So your vex_mountain SOP has a single-float field called 'height': add an attribcreate SOP and set a float value called 'height'. The vex SOP should now use that for the value of height.
Thank you everyone.
Thank you edWard.
edWard`s idea is able to Simply nurbs.
I try make curve(motin line) from particle point.
And nurbs object make the curve by skin.
Last work ..the nurbs shading like flowing...
But your idea of $BBX..etc have some of problem.. to free moving with particleCurve...
So i test it with use $UV,$LIFE..etc..
But i run into a brick wall..
Please me...
My test scene attache...
test01.hip
Edited by mayalife
