Drunkenpanda Posted April 19, 2023 Share Posted April 19, 2023 (edited) Hello, i have been trying to set the upvector to the normal of the plane formed by the joints the problem is that whatever i try it doesnt work in 1 of the joints. In essence it should just work if i take 3 joints of leg, make a polygon and then figure out a way toset the axis to the parent, one axis(up?) to the normal of that polygon and 1 axis to their cros product. (there is also one step where i try to set the pivot of a transform to the eulers of the lookat from axis to the normal so that i can scale it to pake sure the leg is on 1 plane if it hase more then 3 points) but whatever i try, everything is just off, Could anyone help me out ? In essence it should just work if i take 3 joints of leg, make a polygon and then figure out a way toset the axis to the parent, one axis(up?) to the normal of that polygon and 1 axis to their cros product. (there is also one step where i try to set the pivot of a transform to the eulers of the lookat from axis to the normal so that i can scale it to pake sure the leg is on 1 plane if it hase more then 3 points) but whatever i try, everything is just off, Could anyone help me out ? to do the scaling part i use this code. it works in some cases but ometimes the agle is 45 degree of in one axis. vector v1 = normalize({0, 1, 0}); // Define the first vector vector v2 = @up; // Define the second vector matrix3 m = lookat(v1, v2); // Create a matrix that rotates v1 to face v2 vector4 q = quaternion(m); // Convert the matrix to a quaternion vector v1 = normalize({0, 1, 0}); // Define the first vector printf("Rotation angles: (%g, %g, %g)\n", degrees(e.x), degrees(e.y), degrees(e.z)); vector v2 = @up; // Define the second vector matrix3 m = lookat(v1, v2); // Create a matrix that rotates v1 to face v2 Edited April 19, 2023 by Drunkenpanda Quote Link to comment Share on other sites More sharing options...
