VEX - Create an array of all operators piped into a particular node.
Hello! I'd like to dynamically create an array in VEX that contains a list of all the node names that are piped into a merge.
Example:
I'd like to use some VEX inside the crowd transition node that can call on an array of string names that all come from the pink crowd state nodes that are piped into the merge.
Is this possible at all?
I suspect this might be a task better suited for python versus VEX, and likely both easier and quicker that way- you might want to drop this question in the "Scripting" subforum here for better visibility from the coding gurus
  • 2 weeks later...
Create a Python SOP, paste the following code:
nodeParm = hou.pwd().evalParm("spare_input0")
node = hou.node(nodeParm)
geo = hou.pwd().geometry()
nodeInputs = node.inputs()
geo.addAttrib(hou.attribType.Global, "inputs", [""])
inputs = []
for i in range(len(nodeInputs)):
    inputs.append(nodeInputs[i].type().name())
geo.setGlobalAttribValue("inputs", inputs)
Add a Spare Input on the Python SOP and drag the node you want to query into the field. The Python SOP will generate a Detail attribute with a list of node types that are connected to the specified SOP.
  • Like 2
Thanks for the tips @Fenolis. Getting a little closer, but not quite what I was after. This method does show me some relevant info, but not an array list of node names.
I'll leave this for now, as I was initially looking for a quick solution to something. I can see now it's a bit more complex than I initially thought. I can get by on this particular job by entering the node names manually.
