Coz_y_not Posted June 17, 2023 Share Posted June 17, 2023 (edited) In attached hip file, I need to convert the ramp position into an attribute. I don't know how many positions therefore colours there will be. I've tried by copying the parameter ramp1pos BUT it turns out it's only the first position, ramp1pos. There are apparently as many ramp#pos as there are colours. How do I tell each point, this is your ramp position? how do I create an attribute from the ramp position procedurally not knowing how many colours there will be, it could change. ramppos.hiplc Edited June 17, 2023 by karen Quote Link to comment Share on other sites More sharing options...
Atom Posted June 17, 2023 Share Posted June 17, 2023 (edited) Try using a fit inside a point wrangle driven by your id and maximum expected id value. int max_id_value = 5; f@ramp_position = fit(i@id,0,max_id_value,0.0,1.0); Edited June 17, 2023 by Atom Quote Link to comment Share on other sites More sharing options...
