Redshift node inputs
Hi! Could you tell me please, is it possible somehow to display the green dots of the material node I need, so as not to open them every time? That is, I want to stay these green dots by default, so that I can connect nodes directly to them (as in the image 2), without having to drag connectors on base properties.
Not sure exactly what you mean but to have those port showing the connections you need to input something.  You could create an OTL so you do not have to go inside the builder to connect textures, etc. all the time.
