archz2 Posted August 25, 2023 Share Posted August 25, 2023 (edited) I am trying to develop pyro spread beginning from top of some rock pieces using the following tutorial. https://www.youtube.com/watch?v=jsjx3wsdHvk The spread gets successfully initiated if I use some spheres and their top portion gets highlighted. But nothing happens when I use the rocky pieces. Moreover, in the tutorial, at 11 min 12 secs., the tutor mentioned to write 'YMAX' when the groupcreate SOP it to be connected to it. But I failed to get the desired output. However, when I wrote 'YMIN', I got the desired output. What is happening? PYRO INJECT+VELLUM_forums.hip Edited August 26, 2023 by archz2 Quote Link to comment Share on other sites More sharing options...
bengaet Posted August 27, 2023 Share Posted August 27, 2023 i could not replicate your issue, YMAX is working as expected for me. however I replaced your grouping process with a little bit of vex vector bbox = relbbox(0,@P); if(bbox[1] == 1){ @group_burn = 1; } PYRO INJECT+VELLUM_forums_2.hipnc Quote Link to comment Share on other sites More sharing options...
