samesami Posted September 18 Share Posted September 18 I have a sample scene for Houdini to get the time and date using python and display it using font sop but it's now working. I will be grateful if somebody can help me. Thanks node = hou.pwd() geo = node.geometry() # Add code to modify contents of geo. # Use drop down menu to select examples. import datetime import hou # Get the current system time current_time = datetime.datetime.now() # Convert the datetime object to a string time_string = current_time.strftime("%Y-%m-%d %H:%M:%S.%f") point = geo.createPoint() current_time_attrib = point.addAttrib(hou.attribType.Point, "current_time", 0.0) point.setAttribValue(current_time_attrib, time_string) Get_OS_Time.hipnc Quote Link to comment Share on other sites More sharing options...
lugnut Posted September 19 Share Posted September 19 1- addAttrib is a method of geo, not point 2- since you are referencing a detail attrib in the font sop you want to use a detail attrib which is attrib type Global ( lines 19 and 22 in python sop) 3- with the addAttrib functions, the default value tells you what flavor of attrib ( int, float string etc) so a string attrib needs a default string, in this case "" 4- you get a string from a detail attrib with the details() expression not detail() ( in the font sop) 5- also in the font sop you referenced the attrib by the wrong name, the variable in the python code is "current_time_attrib" but you named the attrib simply "current_time" Hope this helps! -jb 1 Quote Link to comment Share on other sites More sharing options...
samesami Posted September 19 Author Share Posted September 19 2 hours ago, lugnut said: 1- addAttrib is a method of geo, not point 2- since you are referencing a detail attrib in the font sop you want to use a detail attrib which is attrib type Global ( lines 19 and 22 in python sop) 3- with the addAttrib functions, the default value tells you what flavor of attrib ( int, float string etc) so a string attrib needs a default string, in this case "" 4- you get a string from a detail attrib with the details() expression not detail() ( in the font sop) 5- also in the font sop you referenced the attrib by the wrong name, the variable in the python code is "current_time_attrib" but you named the attrib simply "current_time" Hope this helps! -jb Thank you for your help. 1 Quote Link to comment Share on other sites More sharing options...
