Sinbad Posted October 13, 2023 Share Posted October 13, 2023 Hello, I've got a question because I'm getting stuck on something while figuring out karma: I import a geo from SOP and with a render_geometry_settings node I set it to treat as light with a specific LPE to make it a geo-light, except that when I get to karma to make my aovs and split them by LPE, I realise that Karma only generates AOVs for "classic" lights (dome-light) and none for my geolights - here are two screenshots, if anyone has a solution or ideas I'd love to hear them, as I can't find much online at the moment on the subject of geolight LPE in karma. Quote Link to comment Share on other sites More sharing options...
toketronic Posted August 19, 2024 Share Posted August 19, 2024 Hey I'm stuck the same place did you find a way? Or perhaps another solution? Thanks Quote Link to comment Share on other sites More sharing options...
besit Posted November 27, 2024 Share Posted November 27, 2024 Trying to solve the same thing. Any updates? Quote Link to comment Share on other sites More sharing options...
pabushka Posted December 22, 2024 Share Posted December 22, 2024 HI basically you'll need to create the AOV yourself if you want to have a geometry light AOV. 1. add a new var (found at the bottom of the karma render settings ) 2. give it a name so you can identify the AOV 3. in "Source Name" you'll need to write the "C.*<L.'LPE Tag Name'>" from what I can tell of what this means is: C = color (Beauty AOV) L = light '' = string value . = It's most likely so the machine knows where the names stops <> = indicate the value (I think...) * = I have no idea why it's there but it's most likely to the the computer that we want B (Light LPE tag) within A (Beauty AOV). I know we can use this with other AOVs liike combined diffuse. A good way to learn how to write for different AOVs is to create a light, give it a LPE tag, in karma render settings activate the AOV you want (Beauty, combined diffuse), check split LPE tags and look in geometry spreadsheet "Render>Products>Vars>"the light you're looking for" and it should show how to write your own AOVs. Here are links to houdini documentations. https://www.sidefx.com/docs/houdini/nodes/lop/karmastandardrendervars.html https://www.sidefx.com/docs/houdini/nodes/vop/kma_material_properties.html https://www.sidefx.com/docs/houdini/nodes/lop/rendergeometrysettings.html https://www.sidefx.com/docs/houdini/solaris/kug/materials.html#emissive And a video of a kind gentleman.... 1 Quote Link to comment Share on other sites More sharing options...
TastySoul Posted January 9, 2025 Share Posted January 9, 2025 (edited) You can add an LPE tag node right before karma. Add your geometry lights to the list by clicking on teddy bear icon in the middle and give them tags. Then you can include these geometry lights in karma render settings and they should show up for you in the render primitive list. Earlier I gave my sky lights an 'Untagged_Lights' tag so they wont have layer, if you need them just give them a tag or remove the 'Omit LPE Tags checkbox' Did this for my lightning which is emissive mesh treated as light source Edited January 9, 2025 by TastySoul 2 Quote Link to comment Share on other sites More sharing options...
RoseCliver Posted January 18, 2025 Share Posted January 18, 2025 (edited) On 10/13/2023 at 8:07 AM, Sinbad said: Hello, I've got a question because I'm getting stuck on something while figuring out karma: I import a geo from SOP and with a render_geometry_settings node I set it to treat as light with a specific LPE to make it a geo-light, except that when I get to karma to make my aovs and split them by LPE, I realise that Karma only generates AOVs for "classic" lights (dome-light) and none for my geolights - here are two screenshots, if anyone has a solution or ideas I'd love to hear them, as I can't find much online at the moment on the subject of geolight LPE in karma. 부산비비기 I've got a question because I'm getting stuck on something while figuring out karma: I import a geo from SOP and with a render_geometry_settings node I set it to treat as light with a specific LPE to make it a geo-light, except that when I get to karma to make my aovs and split them by LPE, I realise that Karma only generates AOVs for "classic" lights (dome-light) and none for my geolights - here are two screenshots, if anyone has a solution or ideas I'd love to hear them, as I can't find much online at the moment on the subject of geolight LPE in karma. Edited January 18, 2025 by RoseCliver Quote Link to comment Share on other sites More sharing options...
