Doptransform
rdg
Hello,
if I understand DOPtransform it applies the transform of an RBD object to an group of primitives at SOP level.
Instead of object merging, wich pulls the geomtry back of the RBD back into this context, it should fetch only the transformation.
I have experimented with the sample scene but I cannot get it to work.
I create a simple setup:
a dropping box and a box that should get this transform.
But the movement of the new box is rather weired.
Could you please explain me where I went astray?
Georg
rdg_doptransform.hipncFetching info...
Hi Georg,
the doptransform only binds the input group to the transform, just like parenting, when You shift the target box to the same location like the source You get the desired result
or You apply the initial position in DOPS
greetings
Martin
  rdg said:
Hello,
Georg
