Triggering A Sequence Reload Using Hscript
ofer
You can bypass then un-bypass the File COPs:
opset -b on /img/file1; opset -b on /img/file2
opset -b off /img/file1; opset -b off /img/file2
Or "click" on the Reload Sequence button:
opparm -c /img/file1 reload; opparm -c /img/file2 reload
Do "help opset" & "help opparm" in the textport for more information.
Cheers!
steven
Thanks! I just figured the second method myself.
But I have a strange problem, when I put a script as a post-frame script in a COP ROP File Output, the script doesn't run, and when trying to render a sequence, only the first frame is rendered.
I am able to run my scripts when using a mantra ROP.
Edited by ofer
