python - get all parms exclude specific specific folders
# check if the parameter is inside a specific folder.
#this code doesnt
        tmp = ['info','Image Settings','Color Settings']
        for folder in tmp:
            if folder in parm.containingFolders():
                print("excluded : " + str(parm.name()))
                continue
# this code works
        if 'Export Presets' in parm.containingFolders():
            continue
cant really figure why the list method doesnt work. Something i am missing?
found another solution that works.
for parm in parms:
        skip_parameter = False
        # Check if the parameter is inside a specific folder. This is in case I want the parms of the HDA itself
        for folder in exclude_folders:
            containing_folders = parm.containingFolders()
            if folder in containing_folders:
                # Exclude parameter
                skip_parameter = True
        if skip_parameter:
            continue
