kiryha Posted January 16, 2024 Share Posted January 16, 2024 (edited) I am applying materials to the USD file objects in Solaris using"name" attributes from groups. Then I can apply individual materials to "sphere" and "box": If I use the "Copy to Points" node it also works, but until I check the "Pack and Instantiate" option. Then I lost my groups, I could only see combined mesh in Solaris. I tried to promote groups after copy but it did not work: copy_instances_usd.hiplc What is the typical workflow for such scenarios? Is it possible to fix this setup, or do I need to export to USD each instanced object separately (box.usd + sphere.usd)? Edited January 16, 2024 by kiryha Quote Link to comment Share on other sites More sharing options...
kiryha Posted January 19, 2024 Author Share Posted January 19, 2024 (edited) The solution would be to turn off "Pack and Instance" in Copy to Points and pack it before copying: copy_instances_usd.hiplc Edited January 19, 2024 by kiryha Quote Link to comment Share on other sites More sharing options...
