Get groups in USD when copy as instances
I am applying materials to the USD file objects in Solaris using"name" attributes from groups. Then I can apply individual materials to "sphere" and "box":
If I use the "Copy to Points" node it also works, but until I check the "Pack and Instantiate" option. Then I lost my groups, I could only see combined mesh in Solaris.
I tried to promote groups after copy but it did not work: copy_instances_usd.hiplc
What is the typical workflow for such scenarios? Is it possible to fix this setup, or do I need to export to USD each instanced object separately (box.usd + sphere.usd)?
Edited by kiryha
  • kiryha changed the title to Get groups in USD when copy as instances
