Match Camera Lenses To The Real World
i am havin problems matching my houdini to a photo that i took, i tried reading the help section about matching a virtual camera to a virtual one:
There are some basic mathematics we can use to relate a real world camera to Houdini cameras. On the following page are some useful formulas.
Variable Definition Default value in Houdini
fovx field of view in X -
fovy field of view in Y -
apx aperture in X 41.4214
apy aperture in Y -
focal focal length 50
resx pixel resolution in X 320
resy pixel resolution in Y 243
asp pixel aspect (width/height) 1
Three key relationships:
fovx = 2 * atn( (apx/2) / focal )
tan(fovy/2) = (apy/2) / focal
apx/apy = (resx * asp) / resy
Useful equations derived from the above:
apy = (resy*apx) / (resx*asp)
fovy = 2*atan( (apy/2) / focal )
Solving for the above given Houdini defaults:
fovx = 2*atan( ( apx / 2 ) / focal ) = 2*atan( ( cam1/aperture / 2 ) / cam1/focal ) = 2*atan( ( 41.4214 / 2 ) / 50 ) = 45˚
apy = (resy * apx) / (resx * asp) = (243 * 41.4214) / (320 * 1) = 31.454376
fovy = 2*atan( (apy/2) / focal ) = 2*atan( (31.454376 / 2) / 50 ) = 34.9213˚
and i am finding it hard to understand the relationships of the formulas between the virtual camera and the one used to take the picture.
here is the meta info of the picture i am using:
File name : img_2085.jpg
File size : 2434196 bytes
File date : 2007:04:25 12:41:20
Camera make : Canon
Camera model : Canon EOS 350D DIGITAL
Date/Time : 2007:04:24 03:51:41
Resolution : 3456 x 2304
Flash used : No
Focal length : 18.0mm (35mm equivalent: 29mm)
CCD width : 22.20mm
Exposure time: 0.025 s (1/40)
Aperture : f/3.5
ISO equiv. : 100
Whitebalance : Auto
Metering Mode: matrix
Exposure : Manual
Exposure Mode: Manual
Exposure Mode: Auto bracketing
how does this relate to the formulas?
thanks
amir
short answer:
put "CCD width" to aperture, and "focal length" to "focal length".
long answer:
you can check
http://en.wikipedia.org/wiki/Angle_of_view
for a literal but yet formal introduction to the concept of angle of view calculations.
from that, it's clear that the too most important datas are the focal length of the lens in use and the size of the sensor (whatever if it's film or some electronics). and this is the point of understanding that what houdini call aperture is the horizontal size of your sensor in milimeters. (in fact the term aperture is more often used for the aperture of the lens (as it happens in your meta data) and not the camera, but that's a different thing. while it's totally correct, it can be a bit misleading)
you can check it if you create a spare attribute on your camera in houdini, call it fov (field of view) and add an expression to it:
2*atan(ch("aperture")/(2*ch("focal")))
(which is the first equation on that page.)
this will calculate the actual field of view (angle of view) of your camera. you can compare the results to the table in the above mentioned page. (set 36 to 'aperture' to get a 35mm film size sensor to check the table, or 22 in your definite case.) the calculated value will be the horizontal fov. the vertical fov can be calculated from the proportions of the resolutions. you can think of it, if that helps, as if you woud have a square sensor with the calculated fov, and a gate before it with the given resolution and proportions.
hope it helps.
bmt
