Kuro Posted February 1, 2024 Share Posted February 1, 2024 I am trying to make some RBD objects float in a flip simulation. RBD objects does not have any unnecessary attributes. And I turned up feed back scale too. It is working with some simple boxes but not with fbx objects. I am uploading my files, please have a look and if you can find a answer please tell me. Thanks check.fbx Floating_objs_flip.hip Quote Link to comment Share on other sites More sharing options...
Atom Posted February 1, 2024 Share Posted February 1, 2024 Only RBD Hero objects can float on FLIP. ap_flip_moves_hero_012524.hiplc Quote Link to comment Share on other sites More sharing options...
Kuro Posted February 2, 2024 Author Share Posted February 2, 2024 But i guess rbd hero object node can only account for 1 object at a time right? for example, if you pass 3 objects with different name through it, it'll solve like all there objects are one object altogether. so do i have to take a rbd hero object node for every object in my scene? Quote Link to comment Share on other sites More sharing options...
Atom Posted February 2, 2024 Share Posted February 2, 2024 (edited) It looks like the old-school RBD solver can do that just fine. Here is a discussion on SideFX about that. https://www.sidefx.com/forum/topic/94452/#post-412963 I applied the suggestions to the posted test scene to produce a proof-of-concept. Play with the density of the fluid and the RBD objects by changing the values on the Physical tabs. ap_RBD_FLIP.hipnc Edited February 18, 2024 by Atom 1 1 Quote Link to comment Share on other sites More sharing options...
Kareeem Posted June 24, 2024 Share Posted June 24, 2024 Would this be possible with the new FLIP SOP nodes? Quote Link to comment Share on other sites More sharing options...
