steve-o Posted May 2, 2007 Share Posted May 2, 2007 I was wondering if anybody could shed some light on a good expression to change the point numbers of the sort sop upon the hitting of particles. I am trying to make a particle hit a grid and upon hitting the grid, an explosion of particles will come off the grid. To simplify, dust from bullets or missiles or whatever the case may be. This is all experimental and I am doing this to better understand and learn Houdini. I can get one particle to work but not on a multiple level. Any suggestions or help??? Attached is a hip file that may explain what I am doing. partcle_birthing_test.hip Quote Link to comment Share on other sites More sharing options...
michael Posted May 2, 2007 Share Posted May 2, 2007 check out the split POP Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted May 2, 2007 Share Posted May 2, 2007 Hey steve-o, if the split pop doesn't work for you and you still want to birth from a grid how about using one particle system to act as the bounding system for another particle system? I've attached a simple example. Alvin selectPointsForBirthPOPs.hip Quote Link to comment Share on other sites More sharing options...
steve-o Posted May 2, 2007 Author Share Posted May 2, 2007 Hey Alvin, Thanks, that actually looks simpler that my first idea Steve-o Quote Link to comment Share on other sites More sharing options...
3__ Posted May 2, 2007 Share Posted May 2, 2007 also using groups if sending from one popnet to another... & don't forget the craters. b.t.w. its probably better to crater with sine & Cd in a point sop. -cpb partcleSpawn_newpOp.hipnc Quote Link to comment Share on other sites More sharing options...
edward Posted May 2, 2007 Share Posted May 2, 2007 This is awhile back now but I think one of the helpcard examples of Split POP show exactly this? Quote Link to comment Share on other sites More sharing options...
3__ Posted May 3, 2007 Share Posted May 3, 2007 & the old particle sop. -cpb partcleSpawn_oldpOp.hipnc Quote Link to comment Share on other sites More sharing options...
steve-o Posted May 3, 2007 Author Share Posted May 3, 2007 Thanks everyone. This helps me out greatly! Steve-o Quote Link to comment Share on other sites More sharing options...
