GallenWolf Posted May 7, 2007 Share Posted May 7, 2007 Hey all! I'm working on my first model in Houdini, can't show it unfortunately, but is there a similar way to do 3DSMax's Target Weld in Houdini? Right now I'm using an Edit SOP to snap the points, and then use a Fuse SOP to weld them together. I have no issues with the tools - just want to improve my workflow. Also, is there a way to move a line segment along edges? I.e. restrict the movement of vertices along the edges? Thanks! Regards, Alvin Quote Link to comment Share on other sites More sharing options...
thekenny Posted May 8, 2007 Share Posted May 8, 2007 GallenWolf said: I'm using an Edit SOP to snap the points, and then use a Fuse SOP to weld them together. I have no issues with the tools - just want to improve my workflow. No, you are doing the right thing. Quote Also, is there a way to move a line segment along edges? I.e. restrict the movement of vertices along the edges? Thanks! not really... unless you have template and modify the snapping options. CTRL+Shift+j will give you the dialog. You can try to rank geoEdge at a higher rating and see if that works for you. If you are looking for a nice way to redistribute points along an edge.. that is a long standing RFE as far as I know. I never tried it but I think SimonBarrick put out a HDK SOP that could allow you do something like it. You should be able to find it on the forums with a search. -k Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted May 8, 2007 Author Share Posted May 8, 2007 Hi! Hey thanks! I'll look at the template options :-) Regards, Alvin Quote Link to comment Share on other sites More sharing options...
sibarrick Posted May 8, 2007 Share Posted May 8, 2007 thekenny said: I never tried it but I think SimonBarrick put out a HDK SOP that could allow you do something like it.You should be able to find it on the forums with a search. -k Houdini Tools - pointslide Quote Link to comment Share on other sites More sharing options...
