Eval Expression
kubabuk
I have a following situation. I've created several variables and using while loop I want to concatenate two strings to form a variable name, in each loop different one. I am not sure if I used eval expression properly but with or without that doesn't work/ :( Could someone point me out what is wrong here, please ?
set box1 = "Rb05"
set box2 = "Rb06"
set box3 = "Rb07"
set i = 0
while ($i < 3 )
set i = `($i+1)`
echo `eval(strcat("$box",$i ))`
end
thanks
kuba
set box1 = "Rb05"
set box2 = "Rb06"
set box3 = "Rb07"
set i = 0
while ($i < 3 )
set i = `($i+1)`
end
thanks
kuba
You can also do this by:
val = ${Rb$i}
The stuff inside the {} is expanded to determine the variable name.
