Scatter Sop Point Normals
Hello,
I have a Grid SOP connected with a Scatter SOP.
When I append a Point SOP and "Add normals", and display them I see NO point normals.
When I 'bypass' the Scatter SOP, I do see the point normals (all the Grid points...)
How can I display the point normals of only my scattered points ?
thanks,
bern
The normals are there, however they have no direction (0,0,0), so you don't see them. This is caused by the fact that the points are not actually a surface and Houdini doesn't really know what direction all the points should be facing. If you change $NX $NY $NZ to be 0 1 0 you will get your standard upwards facing normals.
or you can put your point sop before the scatter sop and the normals should be inherited.
L
