Rendering emissive transparent shaders
SebNotreal
Hello everyone!
I have scene with emissive volume and no density rendered in Karma which is being comped over footage. Issue: since its emissive transparent pixels I was unable to replicate the exact look in AE. Currently ignoring the transparency and using screen blend mode. I have read about straight and premul alpha, but couldnt implement these findings.
I know its impossible to have volumes emit light, while not blocking any light, but it would save a ton of time to render without density.
Anyone stumbled upon this and found elegant simple solution?
Essentially I want to have at least some sort of see through edges and full opaque volume inside dense areas.
Thank you very much for any help, I might want something impossible, but that's where creativity comes :D
