Dag Posted May 5, 2024 Share Posted May 5, 2024 (edited) Hi, I have an instance node with transform on the object level. I want to import this node with the instanced geo to LOP network, but I get just one point and the transform is also lost. How can I import the instance node with the transforn and instanced geo to LOP? Thanks!!! Edited May 5, 2024 by Dag Quote Link to comment Share on other sites More sharing options...
Jordan Walsh Posted May 10, 2024 Share Posted May 10, 2024 Use the Instancer LOP.. sop import the instance geo into LOPs then plug into input two of the Instance lop, object merge the points into the instance lop. Default settings will look for points internally and instance geo as input 2 Quote Link to comment Share on other sites More sharing options...
Dag Posted May 10, 2024 Author Share Posted May 10, 2024 Thank you very much!!!! It works fine Quote Link to comment Share on other sites More sharing options...
