MENOZ Posted May 16, 2024 Share Posted May 16, 2024 hello! I've checked Nick's example file of rbd bullet solver https://www.nicholas-taylor.com/blog/houdini-bullet-physics-tips-2 and I've noticed that to have an object made of various disconnected shapes, like a hammer in the example, you need to use constraints and let each part have its own distinct name attribute. I also know that if i use the same name for a bunch of pieces bullet will interpret them as a compound shape without need of constraints. I am not able to have bullet sop to work in that way. Is that a choice by design? or am I missing some details? I think this is option in the solver is what make this possible - the "Set of connected primitives" I believe is defined by having the same name attribute. Attached an example file showing how this works with bullet dop and how you would need to set up the constraints with bulet sop. Anyone could point me in the right direction? rbdCompound.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 17, 2024 Share Posted May 17, 2024 @MENOZ More info Please rbdCompound(2).hipncFetching info... 1 Quote Link to comment Share on other sites More sharing options...
MENOZ Posted May 17, 2024 Author Share Posted May 17, 2024 oh I didn't tried to pack the geo before passing it through the rbd configure. I assumed that it was accepting only polygons and always packing it afterwards. Thanks! Quote Link to comment Share on other sites More sharing options...
