Weird spikes in waves flip sim
Some miss-clicked may take you to this issue. The velocity advection behavior from gird needs maintains advection by pressure however it ignores the pressure post-solve of the flip solver.
This is a basic Shelf Tool uses guided flip sim with collision object. Simply recreate it from the shelf tool. I estimate it will take about 1 minute to resolve this issue.
@haggi @paranoidx thanks for the reply guys, the gravity was there, the problem was that i wanted faster waves so i increased the time scale in the spectrum and that was causing problem with the velocity, but i still havent find a way to have faster waves without encountering this problem, do you have any tips on how to solve it?
Here are some friendly suggestions based on what I've observed:
  • Try reducing the high-frequency waves in the ocean and focus on the low-frequency ones.
  • In the Flip Solver settings, go to the Volume Motion tab and increase the Velocity Smoothing to make the water movement more gentle.
  • Consider adding more pre-roll frames to allow the water to settle down, such as 500 frames initially if necessary.
  • Increase the domain size to around 200 meters for a better simulation.
  • You can use a Force node to control the Particle Velocity Input of the Flip Solver and direct the waves as desired.
Result in this image
