chrizzl3d Posted May 30, 2024 Share Posted May 30, 2024 I am currently following a tutorial “Houdini isn't scary” which is about replacing a scatter node with a DOP system via a switch node. The problem is that the “attribute transfer” node does not transfer the normals of the geometry to the DOP system. i have actually followed the steps in the tutorial exactly. Houdini3.hiplc Quote Link to comment Share on other sites More sharing options...
Sepu Posted May 31, 2024 Share Posted May 31, 2024 I do not know the tutorial that you were following but anyway, you deleted the whole geometry on your delete sop so it was not carrying anything - the groups from the extrude sop are primitives not points. Also on the normal SOP you should be computing the normals on pts, not the vertices. Here is a fixed file for you Houdini3_FIX.hiplc Quote Link to comment Share on other sites More sharing options...
