Path Trhough Point Cloud
rdg
I want to generate a non self intersecting path though 2d/3d space.
Think of a spacefilling structure - where some object is copied to every position.
To avoid double faces (reference point selected twice or more) I need to be sure that a point is skipped if the path passes it again.
I was thinking about using the pointcloud functions to find points in a given volume and removing those from the group being processed.
Would this be possible?
Or would it be better to produce such point-sequences outside houdini and import then into chops?
Another idea was to have a lsystem build a structure and process the this points for self intersection.
The resulting animation should look like this:
http://www.count-as-one.net/_mov/grow_01.mp4
I did this with maxscript but deleted the double cubes manually - but using arrays/lists this would have be possible automated.
Thinking about it:
As all subsequent points need to be shifted in time this would require heavy choping.
Maybe the external method is better:
reading a pointcloudfile.
generate a path through it.
find double selceltions and remove them.
generate a point list (numbered)
generate a time list (where growtriggers are recorded)
genereate a normal list (normal of $PT pointing to $PT +1) - but this could happen in houdini.
maybe.
Georg
Houdini just told me again:
DONT THINK_JUST DO.
http://proforma.preset.de/tai-chi-hou-dini...-cg_01_0001.mp4
Base is a lystem generated curve.
Some normal/upvector manipulation and here they grow.
The douplicate cube (not visible in this shot) could be deleted by a manual group.
To get a start in pointclouds(?) I think I will search for a way to select points if they are to close.
happy weekend.
Georg
