kodiak Posted June 28, 2007 Share Posted June 28, 2007 Hi, Anyone knows if there is a way to include a custom IFD snippet into a main render IFD file? I tried to add it to an object as pre/post include, but unfortunately that gets folded in the main file. Also, variations of include, ray_include..etc didn't really lead anywhere. Explanation: there is a heavy point cloud that holds instances of objectA, B..etc. Now when I generate the IFD, the instancing gets folded out into ray_object -i -M calls (and couple of lines of transform/shader..etc data). As the instancing is not changing during the sequence (and I didn't find a way to stop Houdini to cook this per frame), what I'm trying to do is reuse the unfolded instance code in the main IFD sequence. Just to avoid confusion: it's not the object/attribute generation that takes a long time, but actually executing (unfolding) the point instancing. Alternative ways are also welcome. Thanks, Andras Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted June 29, 2007 Share Posted June 29, 2007 Anyone knows if there is a way to include a custom IFD snippet into a main render IFD file?I tried to add it to an object as pre/post include, but unfortunately that gets folded in the main file. Also, variations of include, ray_include..etc didn't really lead anywhere. Explanation: there is a heavy point cloud that holds instances of objectA, B..etc. Now when I generate the IFD, the instancing gets folded out into ray_object -i -M calls (and couple of lines of transform/shader..etc data). As the instancing is not changing during the sequence (and I didn't find a way to stop Houdini to cook this per frame), what I'm trying to do is reuse the unfolded instance code in the main IFD sequence. Just to avoid confusion: it's not the object/attribute generation that takes a long time, but actually executing (unfolding) the point instancing. Alternative ways are also welcome. We've fought with this in the past and there were three solutions. - Wait for Houdini 9. - If your data is static and your camera transforms are seperate you can 'include' all the ray_object -i calls using the "source" command. (Remember that IFD is just a subset of hscript.) - Write a Mantra Procedural which handles all the Instancing. (Basically a Mantra Copy SOP). It makes the instancing IFD generation near instantaneous and mantra renders at same speed or a little faster. I wrote one of these a few months ago and its a huge time saver. Quote Link to comment Share on other sites More sharing options...
kodiak Posted June 29, 2007 Author Share Posted June 29, 2007 Thanks Wolfwood, really handy to know these. Unfortunately option 1 and option 3 are not available this time (need this in about 2 days, preferably today ). As this case is quite optimal from this point of view, I will give option 2 a shot this weekend. Gonna be curious to see how the next version of mantra deals with this. Thanks again, Andras Quote Link to comment Share on other sites More sharing options...
Jason Posted June 29, 2007 Share Posted June 29, 2007 If you're desperate, you could work out a way of using another preprocessor like "cpp" or "m4" perhaps? You could put a tiny wrapper around mantra (an executable shell script ahead of the distributed mantra in the $PATH) which calls your own preprocessor first. #!/bin/tcsh echo "calling mantra how i want to" $HFS/bin/mantra $* Quote Link to comment Share on other sites More sharing options...
kodiak Posted June 30, 2007 Author Share Posted June 30, 2007 Thanks Jason. I think Wolfwoods second method is the one I would prefer to use. (as it could be operated a bit more easily by non-technical users) Now the problem became a bit theoretical as it looks like it's going be ok speedwise..gonna give it a try, but I'm afraid Houdini9 public beta is going to be out by then cheers, Andras Quote Link to comment Share on other sites More sharing options...
