rbdconfigure packed pieces issue
intrinsic
Pack fragments are not the same as pack geo, packed fragments are for separating a large geo into separate pieces with different transforms.
Here is more info
https://www.sidefx.com/docs/houdini/model/packed.html
The RBD configure by default will pack the geometry if you want to decide what to pack or not then unpack and do it manually, or skip the configure and use the assemble, etc nodes like you used to do.
  • Thanks 2
