Non-interfusing Mesh
rdg
If I wanted to model something like this:
http://www.flickr.com/photos/lydd/259642988/
How would I get non-interfusing meshes?
Would all mushrooms be in the sameSOP and I would use a lattice and raySOP to deform them?
Or would every mushroom be a singe OBJ?
Or would I use particels or cloth?
I read a post the the sideeffects forum where oldschool described a technique to choose the right house to fit at defined place. Would this be a method that can be used here?
I could deform the mushrooms by hand - one by one.
As I haven't modeled any mushrooms yet, this is a pure theoretical discussion, though.
Georg
Ask ptakun about his cactusos gardenos entry on SESI challenge...
or from a top if my head:
create a field of static particles with self collision enabled. Give them volume/distance based on mushroom instance it will belong to. (or give you instances size of particles collision distance amount).
sy.
Edited by SYmek
ptakun pointed in the same direction ...
I will see if I can make any sense from your hints.
Georg
