RobiDoes3d Posted August 28, 2024 Share Posted August 28, 2024 How do you use the ripple solver with a moving object? I want to use the ripple solver to create bow waves for a boat. I watched the entagma video and I know about the trick of switching the initial and rest geo. But that didn't work. I also made a simulation with a sop solver for the Initial geo, but it gave me the same problem. I am still using Houdini 19.5 so there's no thickness attribute but i doubt that will solve the problem. Does anyone know how to do this simulation? I have attached a simplified scene and a gif of the issue if anyone's interested. wave.mp4 wave.hip Quote Link to comment Share on other sites More sharing options...
fencer Posted August 28, 2024 Share Posted August 28, 2024 (edited) Looks fine when switch rest and initial. wave_v02.hip Edited August 28, 2024 by fencer 1 1 Quote Link to comment Share on other sites More sharing options...
RobiDoes3d Posted August 29, 2024 Author Share Posted August 29, 2024 (edited) After a couple of hours of testing, I found that blending the deformation in, instead of adding it, helped stabilize the simulation. For whatever reason, all the deformations had to be under the waterline for this to work. wave.hip This is what it looks like with a boat, in case this is useful to future people: Thanks for the reply Fencer. It does look fine, but in my testing on the boat deformations, that dip becomes very chaotic after 200 frames. But, help is always appreciated man Edited August 29, 2024 by RobiDoes3d 2 1 Quote Link to comment Share on other sites More sharing options...
fencer Posted August 29, 2024 Share Posted August 29, 2024 (edited) There're many ways to control motion, fade over time, power, curvature, distance from a boat and so on. Ripple source is important first of all, not just one spot, but boat edge, leading area and so on, need more work here for a good result. Mask by curvature as an example. wave_v03.hip Edited August 29, 2024 by fencer 4 1 Quote Link to comment Share on other sites More sharing options...
ThecreativeACT Posted September 5, 2024 Share Posted September 5, 2024 On 8/29/2024 at 10:53 AM, fencer said: There're many ways to control motion, fade over time, power, curvature, distance from a boat and so on. Ripple source is important first of all, not just one spot, but boat edge, leading area and so on, need more work here for a good result. Mask by curvature as an example. wave_v03.hip 943.02 kB · 8 downloads This is the best. Quote Link to comment Share on other sites More sharing options...
BVFX Posted September 18, 2025 Share Posted September 18, 2025 Hi @RobiDoes3d I'm looking to do something similar to the boat example above but I'm really struggling with the input deformation - how did you get that to look so varied my boat leaves a really hard ripple line that doesn't generate more ripples from it. Quote Link to comment Share on other sites More sharing options...
RobiDoes3d Posted October 6, 2025 Author Share Posted October 6, 2025 On 9/18/2025 at 11:34 AM, BVFX said: Hi @RobiDoes3d I'm looking to do something similar to the boat example above but I'm really struggling with the input deformation - how did you get that to look so varied my boat leaves a really hard ripple line that doesn't generate more ripples from it. If i remember correctly, I think i gave the boat a noise deformation, and when i run it through the solver that created the smaller ripples. Remesh SOP to get uniform geometry -> Mountain SOP to generate the noise -> ripple solver hope this helps Quote Link to comment Share on other sites More sharing options...
albehany Posted October 7, 2025 Share Posted October 7, 2025 Thank you guys Quote Link to comment Share on other sites More sharing options...
