Rafal_Kaczmarek Posted September 2, 2024 Share Posted September 2, 2024 Hi all! I'm having this weird popping issue that is clearly visible especially on a chest part. Has anyone experienced that at some point? I have literally tried everything and by everything I mean every single option that is available in vellum solver and vellum cloth conf. Substeps and constraint iterations don't help at all. Collision passes, don't help at all. There is no forces except gravity. Changing friction doesn't help. Tweaking mass and thickness don't help. Tweaking bend and stretch stiffness/damping/rest length don't help! Changing cloth scale doesn't help. Remeshing doesn't help. Changing objects scale up to 100 doesn't help. Cloth itself is a one sided piece of geo without intersections. There is a gap between cloth and collision source, so there is enough room for vellum. I'm running out of options here. Has anyone experienced that? Could it be a bug? houdinifx_YR6S0pOF7w.mp4 Quote Link to comment Share on other sites More sharing options...
hannes603 Posted September 18, 2024 Share Posted September 18, 2024 (edited) maybe try velocity damping or increase collision passes in solver sometimes it can help Edited February 3, 2025 by hannes603 Quote Link to comment Share on other sites More sharing options...
RoseCliver Posted January 30, 2025 Share Posted January 30, 2025 (edited) On 9/2/2024 at 3:32 AM, Rafal_Kaczmarek said: Hi all! I'm having this weird popping issue that is clearly visible especially on a chest part. Has anyone experienced that at some point? I have literally tried everything and by everything I mean every single option that is available in vellum solver and vellum cloth conf. Substeps and constraint iterations don't help at all. Collision passes, don't help at all. There is no forces except gravity. Changing friction doesn't help. Tweaking mass and thickness don't help. Tweaking bend and stretch stiffness/damping/rest length don't help! Changing cloth scale doesn't help. Remeshing doesn't help. Changing objects scale up to 100 doesn't help. Cloth itself is a one sided piece of geo without intersections. There is a gap between cloth and collision source, so there is enough room for vellum. I'm running out of options here. Has anyone experienced that? Could it be a bug? 부달 Check Lesco Bill houdinifx_YR6S0pOF7w.mp4 6.6 MB · 0 downloads If you’re still dealing with popping issues despite trying all the typical fixes, it might be worth looking into the "Adaptive Substeps" setting in the Vellum Solver or checking your collision geometry for any sharp angles or irregularities, even though the gap looks fine. Sometimes tightening up the cloth’s tension around the chest area with more pin constraints or tweaking bend stiffness could help prevent stretching. It could also be a Candles solver bug or instability, so testing in a new Houdini file or making sure you’re on the latest version might help. Lastly, playing with small forces like wind or noise might help distribute tension more evenly across the cloth. Edited April 23, 2025 by RoseCliver Quote Link to comment Share on other sites More sharing options...
