mikejg Posted September 14, 2024 Share Posted September 14, 2024 I have a school project that requires me to have the .abc (attached) combined with the effects from HF Erode... BasicalIy just want to get the details from a specific frame from the HF Erode and apply to my surface .abc imported from Maya. I tried to use the HF Project on my .abc, but the my abc animation stops the after the HF Erode.. how do I apply the effect accordingly? Maybe even more complex, i saw a thread with simlar question as me below. and 1 response below____ just how do i approach this?? Quote You can sort of hack this by copying the internals of the Heightfield Erode inside a Foreach Loop with Feedback. You'll have to change/relink some of the parameters but it works, I had to do it once. Otherwise yes, timeshift the frame you need and run it through tops by wedging the noise each frame. i tried sth weirder in the the photo below as well, using pythong to reisimulate hf erode node on every frame LMAO. DACIA_SH0040_0029_waveTest.abc Quote Link to comment Share on other sites More sharing options...
Atom Posted September 15, 2024 Share Posted September 15, 2024 You could try something like this, but your source geometry is not high enough resolution to hold the results. Try an attribute transfer after your convert. ap_hf_erode_deforming_terrain_091524.hiplc Quote Link to comment Share on other sites More sharing options...
