cs00bren Posted January 23, 2003 Share Posted January 23, 2003 i've got a spline and i want to skin it. i've tryed using wireframe, sweep and a number of other methods but i can find the right method. what i'm trying to do is create roots, i've got 4 spline projected on to the surface then frofiled. then i want the spline to be think in the center and thin at the edge. i've also tryed adding a attribute and using that but i can't get it to work any help would be useful. if you look at the image attached you can see the base of the tree i want it to look better. cheers bren. Quote Link to comment Share on other sites More sharing options...
anakin78z Posted January 23, 2003 Share Posted January 23, 2003 sweep should work. Try putting $PCT into the scale parameter, and check the results. then you can get crafty and vary the scaling, to get some more organic results. See you later Space Samurai! Quote Link to comment Share on other sites More sharing options...
cs00bren Posted January 24, 2003 Author Share Posted January 24, 2003 that is what i want but it scales in the wrong direction e.g. large on hte out side and small in the middle. it can't seem to reverise it any ideas. cheers bren Quote Link to comment Share on other sites More sharing options...
anakin78z Posted January 24, 2003 Share Posted January 24, 2003 err.... 1-$PCT? Quote Link to comment Share on other sites More sharing options...
ResidnT Posted January 24, 2003 Share Posted January 24, 2003 Have you tried the polywire sop, you will still have to make tweeks to it though. Residnt Quote Link to comment Share on other sites More sharing options...
cs00bren Posted February 6, 2003 Author Share Posted February 6, 2003 cheers anakin78z i don't know why i didn't try that cheers anyway bren Quote Link to comment Share on other sites More sharing options...
