Channel To Sop
petz
hi all,
i did an example to learn using chops in combination with sops for some kind of modeling. for this reason i did a simple scene with a copy-sop and replaced the scale value of the copy with the channel-data. it works fine, but to go further, i would like to use the data for scaling the copies in some "per-point" way. if i have a 10 x 10 grid and a channel with 100 samples, how can i use the chop-data to control the scale of the corresponding copy_to_point, based on the pointnumber?
thanks,
petz
test_scale.hipnc
