Vex With pops
cs00bren
hello.
i was wondering if it was possible to import a particle system and use it to place dark patches at the particle points. this is for a landscape where the particle system is used to instance the trees. i want dark patches under the tree to look dirty.
also i want to know using the same vex can you use the heigth to paint a beach at a curtain heigth so that where ever the landscape is at sea level it has a beach.
the whole idea is that i can use this map for any landscape and it will produce a good scene.
any hello would be very helpful cheers bren.
