TheDude123 Posted 12 hours ago Share Posted 12 hours ago (edited) Hi, I've got 2 animated objects (a and b) that I need to attach another object to (c). The object (c) needs to follow along and pivot from (b), while also animating up and down with the (a). I got it working with static objects, but as soon as I add the forward animation...everything falls apart. I've tried different constraints, but can't seem to get it working. Any pointers would be GREATLY appreciated. Simplified file attached for reference. Also, video of a hand animated example (what I would like to achieve with RBD sim). Thanks! anim.mp4 Constraint_to_Animated_v001.hip Edited 11 hours ago by TheDude123 Quote Link to comment Share on other sites More sharing options...
paranoidx Posted 5 hours ago Share Posted 5 hours ago I did not download the file yet, however the constraint prim should be static in SOP, do TimeShift at Start Frame to make it static Quote Link to comment Share on other sites More sharing options...
