Yors_Void Posted November 21, 2024 Share Posted November 21, 2024 Hi everyone!!! After spending quite a while into a modelling problem. I think I have hit a walll. I´m trying to recreate a structure that I saw in one of my dreams, it was a stepped pyramid of extruded hexagons, perfectly fitted. My approach was to use a line where I previously distributed fittted meshes. My idea was to move the line and erase points on each level of the pyramid in order to get a properly aligned structure. The tricky thing here is that you are not following a linear pattern. For the first level you only have to move left and delete the las point. For the second one you don´t to move (only on Y), you just have to delete the first and last point. The thing is that when I reach a certain level my pattern gets broke out. I´m sure this is not the first time someone is doing this, and also pretty sure that I´m missing something and that there´s a much easy way to do this. I´ll gratefully thanked if a smarter mind could put some light on this problem. Thanks in advance. 00_aproximacion.hiplc Quote Link to comment Share on other sites More sharing options...
Fenolis Posted November 21, 2024 Share Posted November 21, 2024 hex_pyramid.hiplc 2 Quote Link to comment Share on other sites More sharing options...
Yors_Void Posted November 22, 2024 Author Share Posted November 22, 2024 20 hours ago, Fenolis said: hex_pyramid.hiplc 134.62 kB · 5 downloads That´s amazing . Thank you very much. Although I don´t really understand well how you managed to do this. I need to dive deeper into your code. Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted February 18 Share Posted February 18 On 11/21/2024 at 9:28 AM, Yors_Void said: Hi everyone!!! After spending quite a while into a modelling problem. I think I have hit a walll. I´m trying to recreate a structure that I saw in one of my dreams, it was a stepped pyramid of extruded hexagons, perfectly fitted. My approach was to use a line where I previously distributed fittted meshes. My idea was to move the line and erase points on each level of the pyramid in order to get a properly aligned structure. The tricky thing here is that you are not following a linear pattern. For the first level you only have to move left and delete the las point. For the second one you don´t to move (only on Y), you just have to delete the first and last point. The thing is that when I reach a certain level my pattern gets broke out. I´m sure this is not the first time someone is doing this, and also pretty sure that I´m missing something and that there´s a much easy way to do this. I´ll gratefully thanked if a smarter mind could put some light on this problem. Thanks in advance. 00_aproximacion.hiplc 168.24 kB · 1 download Here is a solution almost entirely in SOP, with barely any code: Start with a square, regular (rows=columns, choose any number) grid in the ZX plane, in REVERSE TRIANGLES (default is rows and columns, we don't want that) and transform it with this Transform SOP: scale.z = sqrt(3)/2 shear.y = sqrt(3)/3 This produces a grid of equilateral triangles Then divide SOP it with: [x] Compute Dual enabled and you have an hexagonal grid (inside two adjacent equilateral triangles) Then do a group expand starting from the center primitive, and store the step. Primitives with the same step number are going to be on the same hexagonal ring, so at this point this is over. The rest is left as exercise. 2 Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted February 18 Share Posted February 18 @Yors_Void Here is a version that copies a cylinder to a grid of triangles. hexagon_pyramid.hip 1 Quote Link to comment Share on other sites More sharing options...
Yors_Void Posted February 20 Author Share Posted February 20 Hi @konstantin magnus thank you very much for kind answer. I´m a big fan of your tutorials on youtube. Let me check more in detail your solution and I´ll tell you. Thank you very much. 1 Quote Link to comment Share on other sites More sharing options...
