hbiz Posted November 23, 2024 Share Posted November 23, 2024 I am currently seeking an After Effects artist to create the template described in the Upwork link below. However, I am also curious if it would be possible to achieve the same functionality in Houdini. I believe Houdini could offer greater configurability, but I’m uncertain where to start regarding node selection for the required features. Here’s the link to the job post for reference: https://www.upwork.com/jobs/~021860346067867494341 Any thoughts or suggestions on the best approach would be greatly appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
Sepu Posted November 24, 2024 Share Posted November 24, 2024 Could you do it in Houdini, sure you can, but why? There is no point in doing something like this in H when you can do this type of work a lot easier in AE, Fusion, Nuke, etc. You are adding complexity where it does not need to be. Choose the right tool for the job. Now if for whatever reason you really want to do something like this in H, use COPs. Quote Link to comment Share on other sites More sharing options...
hbiz Posted November 25, 2024 Author Share Posted November 25, 2024 Thanks, Sepu. You make a good point. I'm working on creating an automated system that takes a dynamic collection of photos and generates these videos. I thought Houdini might be a good option due to its dynamic scripting capabilities, but I suppose I could achieve this with the other tools you mentioned. Cheers! Quote Link to comment Share on other sites More sharing options...
