Matt Norris Posted December 3, 2024 Share Posted December 3, 2024 Hi! We're a smallish company and just expanded our pool of Houdini licenses! We have a mix of FX, Core and Engine/render licenses all installed on the same license server. We're currently looking at how our deadline integration works and hit a bit of a wall. We've had a few discussions now about what order licenses are checked out and whether they are being checked out correctly. We have set HOUDINI_SCRIPT_LICENSE to be "engine" However we still seem to be picking up FX licenses on the farm What I was hoping to do is setup a test job that can run on the farm and log exactly which license it grabbed, but I can't for the life of me find out how to query the exact license type from within a hou session. I can use hou.licenseCategory to tell if it's commercial or not I can also use hou.applicationName to check if I'm running hython or FX But is there some way of printing out exactly which type of license the hou session is using? Many thanks! Matt Quote Link to comment Share on other sites More sharing options...
DonRomano Posted December 13, 2024 Share Posted December 13, 2024 Hello, You can run hserver through subprocess and Python this way (from Houdini/Hython otherwise you need to include the path to Houdini binary in your PATH): subprocess.run("hserver --info", shell=True, capture_output=True).stdout.decode() And you'll obtain this kind of output where you can see the license after the "Used Licenses" line: Hostname: XXXXXX [Microsoft Windows 11 Pro x64] Uptime: 1 days, 6:34:30 [Started: Thu Dec 12 09:52:41 2024] License Server: http://xxx:XXXX Connected To: http://xxx:XXXX Server Version: sesinetd20.0.724 Version: Houdini20.5.278 ReadAccess (Ipv4): WriteAccess (Ipv4): ReadAccess (Ipv6): WriteAccess (Ipv6): Using Http: Yes Enabled IPv6: false Used Licenses: + Houdini Core 20.5 User(s): pid=31244(using: true) 100,687 of 130,923 MB available CPU Usage:3% load 0 active tasks (32 slots) And with a bit of regex you should be able to extract what you need Otherwise, you can have a look at the license server api (https://www.sidefx.com/docs/houdini/licensing/publicapi/index.html) it is very useful to monitor license usage. Cheers, Quote Link to comment Share on other sites More sharing options...
