point ID change when using carve
Sead
I enumerate each point of some lines, Get them unique IDs, And then attach a carve node after it and preview ID in viewport everything looks fine,
When I play around with the "Second U" parameter, It turn out like this:
Why my IDs changed.... I want them back, Help!
Reserve_ID.hipFetching info...
Edited by Sead
  On 12/17/2024 at 1:08 PM, hannes603 said:
Reserve_ID.hip   attrib transfer the ids maybe  could help
Expand
Hi, Hannes. Thank you for reply.
Your methods still would change those IDs when they pass another points.
By the way I have solved this problem by group end points and blast it then copy their ID attribute to those points who is missing IDs.
  • Thanks 1
