Sead Posted December 16, 2024 Share Posted December 16, 2024 (edited) I enumerate each point of some lines, Get them unique IDs, And then attach a carve node after it and preview ID in viewport everything looks fine, When I play around with the "Second U" parameter, It turn out like this: Why my IDs changed.... I want them back, Help! Reserve_ID.hip Edited December 16, 2024 by Sead Quote Link to comment Share on other sites More sharing options...
hannes603 Posted December 17, 2024 Share Posted December 17, 2024 Reserve_ID.hip attrib transfer the ids maybe could help Quote Link to comment Share on other sites More sharing options...
Sead Posted December 17, 2024 Author Share Posted December 17, 2024 3 hours ago, hannes603 said: Reserve_ID.hip attrib transfer the ids maybe could help Hi, Hannes. Thank you for reply. Your methods still would change those IDs when they pass another points. By the way I have solved this problem by group end points and blast it then copy their ID attribute to those points who is missing IDs. 1 Quote Link to comment Share on other sites More sharing options...
