6ril Posted January 28, 2025 Share Posted January 28, 2025 Hi there, I'm trying to rig a simple hexapod like robot, with APEX. I've watch quite a few tutorials but never found info on how to fine tune an IK (locking some axis and limiting the range of others). It's pretty much a mechanical arm rig. If anyone can help/point me in the right direction... thanks ! 6ril_IK_APEX.hipnc Quote Link to comment Share on other sites More sharing options...
6ril Posted January 28, 2025 Author Share Posted January 28, 2025 Oh and the lookat on the shoulder might not be necessary, it's just an attempt at "simplifying" the problem since I can't figure out how to limit an IK (locks and angles). If someone know how to limit/constrain IK joints, then the shoulder might be included in the IK chain (only allowing the rotate Y) ? Quote Link to comment Share on other sites More sharing options...
6ril Posted January 30, 2025 Author Share Posted January 30, 2025 I've manage to almost rig it, without APEX, just kinefx, but just almost. I'm almost there, but my problem now is that I'm able to make a lookup pointing to the ik target, I replace the Y position of the target with the shoulder Y value in a rigattributeVop, but it's not enough, when I rotate the body it's not working because I should point to the target projected on a plane (XZ plane of the shoulder bone) and not just I'm failing at making the rigvop network that would "project" the target position into the right plane. I'm also wondering if there isn't a way more straight forward approch to rig this. If I could lock rotation on the joints of the IKchain, I wouldn't even need the lookat ! There's a node called ConfigureJointLimit ! But it's not doing nothing to the IKchain. Seems to be for ragdolls and fullbodyIK. here is where I'm at now, without apex (hip file attachment) 6ril_IK_kinefx.hipnc Quote Link to comment Share on other sites More sharing options...
6ril Posted February 2, 2025 Author Share Posted February 2, 2025 hmm, not very popular.. I've manged to do what I needed for the lookat, but it's actually useless since I can't limit the rest of the leg, I wonder why only FBIK can be limited ? So I'm struggling with a kinefx FBIK, with limits, but it's just horrible to animate, nothing to keep you "inbounds". Quote Link to comment Share on other sites More sharing options...
RoseCliver Posted March 23, 2025 Share Posted March 23, 2025 (edited) On 1/27/2025 at 7:00 PM, 6ril said: Hi there, I'm trying to rig a simple hexapod like robot, with APEX. I've watch quite a few tutorials but never found info on how to fine tune an IK (locking some axis and limiting the range of others). It's pretty much a mechanical arm rig. If anyone can help/point me in the right direction... thanks ! انمي سلاير تحميل 6ril_IK_APEX.hipnc 599.18 kB · 4 downloads To fine-tune IK in APEX, lock specific axes by adjusting the constraints and setting limits on joint rotations. Use minimum and maximum angle settings for range control. Adjust axis weights to prioritize certain movements. Test the rig’s motion and refine the limits until it behaves as needed. Check APEX documentation for specific instruction Edited March 23, 2025 by RoseCliver 1 Quote Link to comment Share on other sites More sharing options...
