How to write velocity clamp in openCL for pyro sim
UpyopyoSky
Hi, I have a openCL question. How can I write a velocity clamp in openCL for pyro sim? In VEX, I write like this:
float speed = length(v@vel);
vector dir = normalize(v@vel);
@vel = dir * clamp(speed, 0, 20);
However, I have no idea how to write it in openCL for a minimal solver mode. I suceeded to use ChatGPT to write a minor change in exisitng code, but not for a full writing.
I am expecting to use a Gas openCL node, and not only write a code but also set options, bindings, Generated code tabs. Thus, it would appriciate if someone provide an example hip file.
Thanks for your assistance!
here is his answer and the code is working;
kernel void kernelName(
    int stride_x,
    int stride_y,
    int stride_z,
    int stride_offset,
    global float * vel_1, global float * vel_2, global float * vel_3
    int gidx = get_global_id(0);
    int gidy = get_global_id(1);
    int gidz = get_global_id(2);
    int xres = get_global_size(0);
    int yres = get_global_size(1);
    int zres = get_global_size(2);
    int idx = stride_offset + gidx * stride_x + gidy * stride_y + gidz * stride_z;
    float3 vel = (float3)(vel_1[idx], vel_2[idx], vel_3[idx]);
    float speed = length(vel);
    float3 dir = normalize(vel);
    vel = dir * clamp(speed, 0.0f, 20.0f);
    vel_1[idx] = vel.x;
    vel_2[idx] = vel.y;
    vel_3[idx] = vel.z;
OpenCL is more difficult than VEX, but may figure out some formats and patterns when comparing other openCL codes, like an inside of gasTurbulence node.
