Jordan Walsh Posted March 26, 2025 Share Posted March 26, 2025 Hi, I have a simple particle integrator for quick RBD pre-visualisation. I wanted to match what I would get from a bullet SIM with no collisions (basically just the initial forces, and gravity) but Rotational Stiffness is modifying the initial angular momentum of the bullet sim, causing the output of my integrator to be different (since Rotational Stiffness is defaulted to 1). Can someone help me add a rotational stiffness/inertial tensor stiffness calculation to my integrator in VEX? Thanks! Quote Link to comment Share on other sites More sharing options...
Librarian Posted March 26, 2025 Share Posted March 26, 2025 Please Post that File . @Jordan Walsh Quote Link to comment Share on other sites More sharing options...
Jordan Walsh Posted March 26, 2025 Author Share Posted March 26, 2025 Here is the file showing my initial vex setup (adding @w to rotation), a bullet sim with Rotational stiffness = 0, which matches my vex setup. And a bullet sim with the Rotational Stiffness = 1 (default) that shows the difference in rotation. I would like to match the Rotational Stiffness = 1 with my vex setup. I hope that helps rotationalStiffness_vex.hip Quote Link to comment Share on other sites More sharing options...
Librarian Posted March 27, 2025 Share Posted March 27, 2025 check this VEX. inertiatensor.hipnc 2 1 Quote Link to comment Share on other sites More sharing options...
Jordan Walsh Posted March 27, 2025 Author Share Posted March 27, 2025 Amazing, thanks @Librarian!! I'll start working my way through it. Quote Link to comment Share on other sites More sharing options...
