rohandalvi Posted September 21, 2007 Share Posted September 21, 2007 hi, I was reading the features in the Houdini 9 Brochure, it mentioned that mantra can do point rendering . The question is how do u do that? Most of the particle tuts I have seen, use either sprites or spheres or metaballs. But i have never seen one that did point rendering. Is this something like the point type particle render in MAYA and Krakatoa ( The new point renderer for 3dsmax form Frantic Films.) Could anyone help , How do u do point rendering in Houdini? with regards Rohan dalvi Quote Link to comment Share on other sites More sharing options...
vmuriel Posted September 21, 2007 Share Posted September 21, 2007 In the Geometry node, you must select the Render -> Geometry -> "Render As Points". With the attribute "pscale" you can control the size of the point. Quote Link to comment Share on other sites More sharing options...
rohandalvi Posted September 21, 2007 Author Share Posted September 21, 2007 thanks a lot man, I never knew that. This software is so huge, I don't think I will ever finish learning it. It's like a 1000 times bigger than max (which is my primary software) But max comparing to Houdini feels like comparing Ms Paint to Photoshop or Painter Anyways, thanks once again. I will try it out. with regards Rohan Dalvi Quote Link to comment Share on other sites More sharing options...
