Blendshape
MENOZ
my stupid work browser wont let me upload files...
but here is the way to do it...
name your mesh ORIGINAL_MESH
mirror you original mesh
mirror your blendshape
use a lattice SOP with:
ORIGINAL_MESH as input #1
the mirror of ORIGINAL_MESH as input #2
the mirror of your blenshape as input #3
turn on the "points" option on the lattice
use the Radius parameter to refine the lattice (start with something like 0.01)
append a null to the lattice - call it OUT
now in the textport cd into you geometry node
/obj/myObject ->
now use sopcreateedit to create an edit node the will be your other blendshape (see help sopcreateedit for details)
/obj/myObject -> sopcreateedit otherSide ORIGINAL_MESH OUT
this will create an edit node called "otherSide"
hope that helps
