Error On Parameter Evaluation
i dont know if somebody has this problem before, but i dont know where to search anymore maybe someone got that problem and could point me in a direction.
i have a sop node with some parameters, there are float and string parameters, i want to use some local variables in this parameters thats why i`ve written
getVariableValue(int index,int thread)
function.
the problem now is, that this evaluation works for the string parameter but not for the float parameters, ... for the float parameters houdini tells me with a mmb on the node
Error: Unable to evaluate expression
File <stdin>, line 1
$ID
syntax error,
invalid syntax (/obj/geo/mynode/attrValue11)
but it evaluates when i use my string paramenter.
Does somebody has an idea?
thx in advance
Sebastian
Hi edward,
yes, i use PRM_FLT_J for the parameters,
and this is the code i use for read the values from the UI, AttribID is used because their is a dynamic list of parameters,
and pos describes the position where to access an e.g. 4 float parameter
float SOP_myNode::getAttribValFloat(int AttribID,int pos,float time)
	float ret_val =evalFloatInst(vaNames[vaVal].getToken(),&amp;AttribID,pos,time);
	std::cout &lt;&lt; "evaluating Float "&lt;&lt; AttribID &lt;&lt; "  " &lt;&lt; pos &lt;&lt;   "  " &lt;&lt; ret_val &lt;&lt; std::endl;
	return ret_val;
int SOP_myNode::getAttribValInt(int AttribID,int pos,float time)
	int ret_val =  evalIntInst(vaNames[vaVal].getToken(),&amp;AttribID,pos,time);
	std::cout &lt;&lt; "evaluating Int "&lt;&lt; AttribID &lt;&lt; "  " &lt;&lt; pos &lt;&lt; "  " &lt;&lt; ret_val &lt;&lt; std::endl;
	return ret_val;
UT_String SOP_myNode::getAttribValString(int AttribID,float time)
	UT_String ret_val;
	evalStringInst(vaNames[vaStr].getToken(),&amp;AttribID,ret_val,0,time);
	std::cout &lt;&lt; "evaluating String  "&lt;&lt; AttribID &lt;&lt; "  " &lt;&lt; ret_val &lt;&lt; std::endl;
	return ret_val;
any idea ?
thx
Sebastian
